jdnet
How To Restore Your Headlights
What causes the blackening of the lights from the inside as oppose to the lense getting oxidated?
Share this post
Link to post
lens getting oxidated? I'm not quire sure what this question is and it should be reflector as oppose to lens I guess.
However, as per my knowledge, two things can happen. The lens will discoloured due to exposing to UV and the reflectors can be oxidated if it's made out of metal and chrome plated. It won't oxidated if it's plated on plastic. Oxidation can happen if the seals are broken and water, moisture get into the light, that is if the reflector is made out of metal. If the reflector is plastic, the discolouration or fading, melting can happen due to high wattage bulbs and low quality reflectors found in cheap substitutes.
Share this post
Link to post
Rangii do you mean the common "smoked light" syndrome we see in most diesel vehicles ? im not exactly sure but i think it happens because of the smoke and carbon monoxide reacting with the plastic :unsure:
Share this post
Link to post
Blackening of the rear light cluster of the diesels I used was due to carbon particles sneaked inside to the light cluster. Used to take the cluster out and clean it time to time in order to keep it in appealing color and the visibility of the lights.
Share this post
Link to post
Is it just me or do the lenses look cloudy after following this procedure?
I simply waxed my headlights with 3M Cleaner Wax, got rid of the yellowing without the lens appearing cloudy.
Share this post
Link to post
Cloudiness depends on how well the job was done. If you sand and polish it right you should be fine. While cleaner wax may have worked for you it will not work on a lens that has turned significantly yellow.
I do fail to see how cleaner wax could work on a yellowed lens though. Maybe your lights were just dirty.
Share this post
Link to post
Well it says on the bottle that it's a "Light Oxidization Remover".
And no they weren't dirty, I actually had to replace the RH side lamp cluster and the replacement I bought was quite yellow but cleaned up like a charm with the 3M.
Also I use it to regularly clean the fogs of my FiLs N16 that dirty up pretty fast, probably due to the close proximity to ground.
You have to rub it with quite a bit of force though.....
Share this post
Link to post
Did mine... I used 1000 and 1500 grit papers with brasso...
The first pic below shows my car's discolored left headlight and the restored right headlights.... The second pic shows both the restored headlights... however I even though we can see the crystals inside i believe it can be made more crystal clear by applying any other polish? any suggestions?
On another note, the discoloration of the fogs cannot be done from outside, cuz water has gone inside and that's why it looks black even though the fog lights work it doesnt look bright.... anyone know a place where i can take this and get it cleaned from inside?
Share this post
Link to post
Did you apply a clear coat?
Share this post
Link to post
Oh no I did not.... just applied brasso... does it make a big difference after applying the clear coat... and also is there a specific brand or anything I should look into? will hardware shops have it?
Share this post
Link to post
Will this liquid work as a clear coat? (I use this as a dashboard cleaner/shiner)
Share this post
Link to post
I have used TOA / Leyland clear coat and it works well, Needs a sand or a polish once dried 3 coats
The liquid is probably a cheap wax,
It would be better if you did apply a clear coat as you've sanded the protective layer up front, Not an expert on this but a bit of reading on the net says it may weaken the lens, with mild cracks appearing with time. therefore by covering it up with a clear coat, you'd restore that layer and the clear coat does not yellow up like the original polymer.
Without a clear coat, I reckon it will be yellow in a matter of months, as there is no protective layer.
Again, not an expert; just DIY experience
Edited by tiv
Share this post
Link to post
I use that on tyres too right after washing when the tyre is wet, it works well
Share this post
Link to post
The liquid is probably a wax/ sealant,
Ok, every paint shop will have that clear coat yeah?
Edited by PreseaLover
Share this post
Link to post
Yea large scale rattle can agents, the cap would be transparent, for identification.
Would be even better if you can get a 2k clear coat sprayed by a painter, and buffed out a bit for more clarity.
Share this post
Link to post
How much would it cost me, if I entrust you to do it for me?
Share this post
Link to post
Lol, you joking right? :P
Share this post
Link to post
Oh I already rushed into the paint store before I saw this comment and purchased it... Here is a pic below... This one noh?
Share this post
Link to post
Spot on, be warned, its gonna haze up once you spray it, within a few hours it will clear up, but to get the ultimate clear finish you need to sand it a tiny bit, or buff it with rubbing compound. Attempt this after about a day of drying.
Edited by tiv
Share this post
Link to post
Ok now I got a few questions....
1. Should I cover the body area of the car with paper or something while spraying or it doesnt affect the paint of the car?
2. how many coats of spray layers should I do? the paint shop dude said apply 2 layers, is that right?
3. What do you mean by rubbing compound? do you mean like after a day of spraying this, polish it with brasso again?
Share this post
Link to post
1 . Cover all areas, remove what you can
2. 2-3 coats
3 Brasso, super cut, v cut etc, Yes
Share this post
Link to post
2. 2-3 coats
Great... thanks a lot for all the advises... will do as said :)
Share this post
Link to post
2. 2-3 coats
Alright, first thing today morning was to apply the clear coat.... Following are the pics on how I did it/before applying the coat, and also how it looks as soon as i applied the coat.... Just after I did it, a big fat black cloud moved my way.... Hope it wont rain :/
Share this post
Link to post
Is there any advantage in pasting those white/blue stickers on headlights? Will the lights never get yellowish again if I paste the white sticker? Is there any affect on using that sticker?
Share this post
Link to post
Create an account
Register a new account
Sign In Now
