Ushie
Corolla 121 - Engine Oil Issue
Hello All,
I daily drive a corolla 121 (YOM - 2000) with 230k km on clock. Recently I'm experiencing a loss of engine oil (very small quantity). I drive this approx 15km daily. Every two weeks now i have to refill the engine oil by approx 1L. No leakage on the floor or no black smoke is producing. What may be the issue on this?
Share this post
Link to post
Experienced this recently (I mean within 2 - 3 days) or is this developed gradually since few months?
Edited by gayanath
Share this post
Link to post
Edited by Ushie
Share this post
Link to post
developed gradually.
Share this post
Link to post
Then it seems general engine wear with this millage (sometimes millage may be bit higher than 230k if previous owners have tampered it).
15 * 14 = 210
1L for 200 km is bit higher consumption so you need an engine overhaul I suppose.
BTW, Which grade oil you are using?
Share this post
Link to post
15 * 14 = 210
15W-40 by Mobil I am using.
I was thinking the same. Asking for an overhaul then it must be neh?
A guy once told me, engine oil may mixed with fuel. This can be happened?
also I have noticed fuel consumption is low from recently. it does around 8-10 kmpl in colombo.
One more thing, Once I start the car in the morning it wont go even i accelerate. Have to keep the car for around 5 minutes to warm up in parking gear. But in low gears and revers gear this never happens.
Share this post
Link to post
seems like either the piston rings or head gasket leaking.Low fuel consumption is due to the compression loss.
Edited by GayanR
Share this post
Link to post
When was the last time (ifever, ~) the transmission was serviced?
Share this post
Link to post
should I replace the rings then?
Share this post
Link to post
Its been 3 months
Share this post
Link to post
Agree with others that it might be engine wear. Get a compression test done first. That will tell you if the engine is worn out (under compression). Depending on the result, you will have to do an full or partial engine overhaul.
Share this post
Link to post
Create an account
Register a new account
Sign In Now
