r3423
Nissan March K11 (YOM 2001) IAC valve dysfunction
Hello there, my Nissan March K11 (2001) has rough idling especially with AC being on. Did a tune up, but no improvement. Mechanic says that IAC valve needs to be replaced. Any leads and guides? TIA
Also, is it possible to buy brand new IAC valves for this car?
Share this post
Link to post
Buy the throttle body fully. I hope this model throttle body have the IAC valve in it.
  • Thanks 1
Share this post
Link to post
Was your ignition system checked ? clogged injectors  could also cause rough running.
Share this post
Link to post
After a cold start (i.e in the morning), does the engine rev upto about 1500 RPM and slowly settle down to normal as the engine warms up?
If the rest of the throttle body is good, and if it is actually the IACV that is faulty, just replace the IACV. There's no benefit in replacing the entire throttle body unless the one on the car has a crack or irreparable damage.
Share this post
Link to post
Yes. Ignition system was fully checked with replacement of plugs and tune-up.
Share this post
Link to post
There's no RPM meter in the dashboard.
Ya. I also thought of replacing only the Vavle. Thanks
Share this post
Link to post
