B2Spirit
Toyota C-HR 1.2L vs Audi Q2 1L
I would like to know Pros and Cons of these 2 vehicles.
Due to the new tax system these 2 vehicles have become attractive.
I checked the specs and noticed that the C-HR is slightly bigger and considerably heavier.
But the power output listed for both engines seems to be around 115PS.
Share this post
Link to post
10 hours ago, VTEC said:
What is the recommended fuel type for the CHR 1.2L Turbo? 92 or 95? A Google search didn't help much...
Japs are good for 92 unless it says premium in the filler cover inside
Share this post
Link to post
Most small turbo engines need 95 octane fuel regardless of it being Japanese or not. If it didn't have a turbo then 92 would be fine unless your manual says otherwise.
Share this post
Link to post
Depend on the engine tune, some non turbo cars recommend 95/98
Depends on the availability of fuel in respective market, for instance UK spec Regular is 95, premium/super is 98 any car imported from UK will need 95
In Japan regular is 89 and premium is 96, majority of the mainstream JDMs are tuned to run on regular irrespective of turbo or not.
Agent imported CRV require 92 octane as per the manual and the sticker in the fuel filer hatch, it is turbo charged
Share this post
Link to post
No...it is a range....these days regular ranges from lower 90s to 95 and Premium/high Oct from 95 to 98/99; depending on the brand.
Edited by iRage
Share this post
Link to post
I said small engines. Most of them require high octane fuel to reduce or eliminate "knock". Even in higher capacity turbo engines its the same principle.
https://en.wikipedia.org/wiki/Engine_knocking
A turbo sends pressurized hot air forcefully into the chambers. a certain compression ratio is needed to produce the high power outputs of these small engines. Fuel quality plays a major role here, low octane fuel might not damage the engine in the long run but it will lose it's quoted power figures and get worse economy.
Share this post
Link to post
95 Octane since it has a turbo charged engine
Share this post
Link to post
Create an account
Register a new account
Sign In Now
