4D56 Turbo / Turbo Intercooler
Nishan.dj
Hi Guys,
Please be kind to clarify the below for me.
In 4D56 Engines, some are non turbo and other are intercooler turbo or turbo.
Is turbo intercooled better than normal turbo engines?
What is the mechanical explanation?
Mostly these engines come with 32- Pajero in SL (Known as Palath Sabha).
Appreciate your reply. Thanks.
2 answers to this question
4D56[edit]
Displacement - 2.5 L (2,476 cc)
Bore - 91.1 mm
Stroke - 95.0 mm
Fuel type - Diesel
This engine is also built by Hyundai in South Korea, meaning it also sees use in some products made by their Kia subsidiary.
Non-Turbo[edit]
  • Power - 55 kW (74 hp) at 4,200 rpm
  • Torque - 142 N·m (105 lb·ft) at 2,500 rpm
  • Engine type - Inline 4-cylinder SOHC
  • Fuel system - Distribution type jet pump
  • Compression ratio - 21:1
Non-intercooled Turbo[edit]
  • Power - 84 PS (62 kW) at 4,200 rpm[13]
  • Torque - 201 N·m (148 lb·ft) at 2,000 rpm
Non-intercooled Turbo (TD04 Turbo)[edit]
  • Power - 90 hp (67 kW) at 4,200 rpm
  • Torque - 197 N·m (145 lb·ft) at 2,000 rpm
  • Compression ratio - 21:1[14]
Intercooled Turbo (TD04 water-cooled Turbo)[edit]
  • Power - 78 kW (104 hp) at 4,300 rpm
  • Torque - 240 N·m (177 lb·ft) at 2,000 rpm
  • Rocker arm - Roller Follower type[15]
  • Fuel system - Distribution type jet pump (indirect injection)
  • Combustion chamber - Swirl type
  • Bore x Stroke - 91.1 x 95mm
  • Lubrication System - Pressure feed, full flow filtration
  • Intercooler Type - Aluminium Air-to-Air, Top-mounted
  • Turbocharger - Mitsubishi TD04-09B
Also known as Hyundai D4BH[16]
Intercooled Turbo (1st Generation DI-D)[edit]
  • Power - 85 kW (114 hp) at 4,000 rpm
  • Torque - 247 N·m (182 lb·ft) at 2,000 rpm
  • Fuel system - 1st Generation Common Rail Direct Injection (CRDi)
  • Compression ratio - 17:1[14][17][18]
Intercooled Turbo (2nd Generation DI-D)[edit]
  • Power - 100 kW (134 hp) at 4,000 rpm
  • Torque - 320 N·m (236 lb·ft) at 2,000 rpm
  • Fuel system - 2nd Generation Common Rail Direct Injection (CRDi)
  • Compression ratio - 17:1[14][17][18][19]
this is taken from Wikipedia...im no expert on this but they heve improved the volumetric efficiency thus increasing power efficiency and torque
