Engine Oil Overfill
Jor-el
The excess oil will probably be burnt off. Nothing to worry.example  If the car holds 4 liters and you put in 6 then it might create issues with the crankshaft but that too very rare.  Engines are created to hold oil on 45 degree angels , specially on tight corners or hills. If you have a very low oil or very high oil level then you should be worried. Other than that for something like this, it’s nothing. You can sleep :D
Edited by TheFlyingFox
If you have 50% more engine oil than you are supposed to, then it will eventually destroy the engine. Guaranteed. Read the first few posts in this thread.
Ohh I knew putting half will create problems but didn’t know it’s guaranteed failure :)
