gada
92 Octane Petrol
Found out that when using 92 Octane petrol the fuel efficiency has dropped and car isn't running as smooth as before.
I was using 90 Octane previously and problems started immediately after the switch.
Has anyone else in this forum experienced a similar issue?
Share this post
Link to post
Well I didn't felt such issue and in fact car became bit smoother.
Share this post
Link to post
Experiencing Smoothness & better acceleration with same km/l
Share this post
Link to post
Thanks guys, then it could be probably something specific to the shed I pumped from.
Hard to imagine an issue with the car because the smoothness and efficiency returned when I pumped 95, but yes it could be other reasons also.
Share this post
Link to post
If they are pure 92 Octane, then it should give you a more smooth drive. So far I haven't experienced anything bad than 90 Oct from 92 Oct. You may having a different problem with your car.
Share this post
Link to post
Switched from 95 to 92 with no issues. Manufacturers recommendation 91 and above
Share this post
Link to post
Members,
My Maruti Omni 30000 Km, done so far no problems up to today. only cleaned the throttle body at 15000 Km.
Till 31st December 90 Octane petrol I was averaging of 11 Km/L to 12.8 in Colombo. 15 to 16 out of Colombo.
New 92 Octane petrol I have so far average of 13.1 Km/L Colombo and out of Colombo mixed. No difference in pick up.
Will try to give more later. I always use Acetone 5% with full tank. Fuel additive which is not recommended by A/L members.
Share this post
Link to post
From where can i get acetone????
Share this post
Link to post
ajwad,
This Acetone you can buy. 1 liter or 5 liters in cans, from Bangshall street Pettah. Cost 5 liters about 1200.00 Rupees.
Share this post
Link to post
You can buy acetone in bankshall street, pettah.
If you are planning to add it to the petrol tank of your car, dont do it. Sylvi is a senile idiot who gives dangerous and nonsensical advice like this.
  • Like 3
Share this post
Link to post
Ajwad : Caveat Emptor. As Sylvi himself points out, its not recommended by many A/L users. Using higher flashpoint fuel in engines designed to run lower might actually cause you issues in the long run, so do yourself a favor and stick the the manufacturer recommended fuel unless you know what you are doing.
Sylvi might be excited at reaching 30k kms on his engine, but Sylvi has a use it a short time and sell it to some poor sucker mentality. Its like the time he wholeheartedly recommended the Nano to all and sundry but then had to eat crow when it proved to be junk.
Also note that if you have a 50l tank and you are pumping 92, you spend enough money adding Acetone to pump a further 3.6l of normal petrol. Assuming the vehicle gets 10kmpl, thats a further 36kms. Does the acetone you add get you better than 36km on the full tank? Is it worth the cost of fouling up your engine?
Swap the numbers around to suit your own fuel capacity and mileage and see what you get first.
Oh, an Crosswind, Don't call the old man a senile idiot. Apparently he finds it offensive and its against the stated rules of the forum to call people offensive things, yada, yada, yada.
Share this post
Link to post
Moderator, Mr. P. Rodrigo,
First of all thank you for your post.
YES.CORRECT I AM A OLD MAN 70+ YEARS OLD. STILL ACTIVE.
I am aware this post will never appear in THIS A/L THREAD.
Under is for your information.
MANY A/L MEMBERS HAD GOT MY ADVICE ON VARIOUS AUTOMOBILE PROBLEMS.
I still use for full tank ½ a bottle of Acetone in my cheap Indian Mruti omni. 32000 Kilometers’ done with no problem.
Edited by Pericles
All the irrelevant BS has been removed.
Share this post
Link to post
Correct grammar is to say "AN old man". Queen's English seems to be slipping somewhat.
Share this post
Link to post
Yes that was a grammar mistake. I admit same.
Share this post
Link to post
Create an account
Register a new account
Sign In Now
