Corolla 121 Vs Nissan Cefiro A33
alpha17
Thanx schiffer..ur ideas are really valuable...mixing 90 octane and 95 octane petrol, is it harmful to the engine?anyway my friend has a 2.0g model,and i've heard many said that cefiro's are not good when it comes to acceleration.is it true?and how does the vvt-i improves the performance?as we both got automatics,can i increase my acceleration by shifting manually?how is the best way to shift manually?
well since you have a automatic. the best way to shift manually is to first go to delkanda and then find a manual gearbox, clutch pedal pressure pump etc etc
then bring it to your local mechanic and swap the automatic gearbox to a manual. the you can shift manually.
also yes. when vvti kicks in you are not having 1500cc. you are having 1547cc it will give more accelartion as the engine gets bigger.
good luck with the race.
Which is better? Vtec, VVTI or Chuck Norris? :)
VVTi. since apparently it doesn't kick in yo!
  • 3 weeks later...
