Power Steering Oil Leaks Help
ellamulla
Hi Guys
I have problem in my power steering system,Power Steering oil leaks I could not notice it ,I was heard a liquid in internet there is liquid for stoping the leakage in hose .Do you have any experince and how do you recommended.
please advise me .
Kumarasiri B.A.L
It is Toyota Lite Ace CR 27.I found it in servise stattion once sevice is completed Fluid(Oil) leaked I drive 10KMs to home without oil.I am Live in Avissawella.
I want to know any "Addictive in market Sri Lanka that can fix in Leakage in this system' I saw in internet 'LUCUS power stering oil leak fix fuied" Do you recommended this .
Kumarasiri B.A.;
Those additives would simply worsen the matter with time.
They just make inner rubber parts/oil seals to swell and unfortunately they have no control over it!
It may be a leaky oil line,pump or steering rack might need repair.
You also get a used rack/pump from a recon spare shop since CR27 is not a rare model!
First I would check where its leaking from. start looking for leaks from the reservoir, pressure line, Return line, power steering pump and the steering. im not a fan of "fix in a bottle" products its nothing like fixing it in a proper way.
There are two types of products out there one that thickens the power steering fluid that it would stop the leak and the other is a chemical that expands the rubber. personally I wouldn't do use "fix in a bottle" products.
