Guys, i know its bad for the socket and and the switch to change the H4 bulbs
from 55w -> 100w
does the same results apply for the H3 bulbs?
The 55w bulbs in my fog lamps are sort of useless at night.
And the foglamps have a plastic cover. Therefore is it okay to install a HID kit?
Share this post
Link to post
i got a set of narva with me mate. but the H3 and H4 are both the Blue glass light. the output is not that much
but im planing to fix the H4 Narva 100W tomorow. till i get a proper 4500K or 5000K H.I.D kit
Narva too has fakes i'm afraid :( I've got caught to it once myself...
Had a set bought off motorcade and those worked brilliantly until i flogged the car off...
Share this post
Link to post
donno about mine :( it says Germany on the bulb and bought this around 6 years ago when i had my FNB 14 (not knowing that had to use 55W for the 14)
Share this post
Link to post
recorded this off my phone lil while ago.
ignore the music :P phone cam has picked up only the high frequencies even when the sub was firing away at the time :P sounds real bajaj audio but its nothing like that in reality... :D
The low beam is 90 and the high beam is 100. Koito and i bet it's fake.
The bright high beam you see will be the hella rallye 2000's kicking in. that too is 100w, hella h1 bulb.
Share this post
Link to post
lol, sounds like ripper is listing to "biscuit kudu" music XD
and seriously those Hella ralllye 2000's are pretty damn impressive :o
Edited by Schiffer
Share this post
Link to post
well i listen to mostly house, trance and a bit of rock. shockingly in real life those highs you hear aren't there. it's a lot of mid range and lows with a bit of highs as fills. stupid nokia has really warped the sounds...
strictly on lights, i too wanna change those fake koitos and either drop a pair of genuine hella h4's or bite the bullet and get a pair of PIAA's... Not on ebay, from a motoring site :D
Share this post
Link to post
lol i was pulling your leg on the "biscuit kudu" music thing :D and not just nokia.. any phone will make a recording into "biscuit kudu"
well i change my stock bulbs to the navra today, and found out that i had a set of original Koito 100W bulbs in it. installed by the previous owner.
but i still change it anyways.. though i change to the blue navra to look 'cool'. the koito which were in the car was really powerfull
Share this post
Link to post
Osram AllSeason Super 55W H3's arrived :sport-smiley-004:
Fixed on the car and tested it against the one good PIAA Plasma Ion 55W
PIAA bulb on the right. Much brighter :(
PIAA(left) is also a lot more yellower @ 2500K
PIAA
Osram
Edited by c1nder
Share this post
Link to post
After fixing both Osram's
Dual PIAA Night Tech 60/55W H4 Head's and Dual Osram AllSeason's Fog's, 220W of pure goodness :D
Edited by c1nder
Share this post
Link to post
Schiffer, I second what terrybytango is suggesting is as well. I did the same with my car as well by replacing the standard spec halogents (55/60) with Koito super bright light producing light equivalent to 100/90. This way there is no extra drain on the battery, little increase in heat and clearly the lights are brighter.
In my older car I just upgraded the halogens to 100/90 and the result was the same but with a lot more heat. The battery and the electricals coped ok with that but the lenses on those headlights were glass while the current ones are plastic.
The Koitos were sourced from Japan. Never seen it sold in SL but they are virtually identical to the Osram Nightbreakers in spec.
now koito is available here im using 100/90 but be careful of counterfits
Share this post
Link to post
Create an account
Register a new account
Sign In Now
