Ekendra Edrisinghe
Hid Xenon Lights
The previous owner on the my vehicle had fitted HID Xenon lights using the old lamp reflectors.
My previous vehicle had the normal lights and to me they seemed to appear brighter at night with greater night visibilty.
My guess is that the old reflectors do not match up with the HID Xenon lights.
Can anyone suggest a HID Xenon expert that I can go to so as to get this rectified?
Share this post
Link to post
Yep, good deal. I got those unbranded ebay 3000k bulbs, wire, and two ballasts for 21$. But couldn't find mounting plates for cheap.
Edited by H.C
Share this post
Link to post
here's the hi's and lo's.
high beam. 3200K 35watt:
low beam. 6000K 35watt:
phone camera isn't the best...
Share this post
Link to post
How did they install projector lenses to normal headlights? or did you bought a headlight with projectors?
Share this post
Link to post
Hope you can fix it with double sided gum stickers I mean the ballast. My previous kit was applied to inside wall above tyres.
Edited by Charith H Jayasinghe
Share this post
Link to post
It was installed to existing headlights after remove front cover using a heat gun. Projectors were fixed to the reflector. They had to remove the cap like part extending from the reflector to cover the H4 bulb.
Share this post
Link to post
Bara stereos in Dehiwela had the projector kit men. Fits most lights. 27,000 with hid set and installatoon
Share this post
Link to post
<blockquote class='ipsBlockquote'data-author="Charith H Jayasinghe" data-cid="244850" data-time="1375766689"><p>
Hope you can fix it with double sided gum stickers I mean the ballast. My previous kit was applied to inside wall above tyres.</p></blockquote>
Managed to fix them at home with thick wire ties and 3M double sided tape. But mounting plates would be neat and tidy.
Share this post
Link to post
I didn't need a wire tie. I was passed nicely with sticker, I mean the size of large face of ballast. They were pretty decent.
Share this post
Link to post
No machan , this is for the fogs. Ive two separate kits placed in the usual mounting area. So not enough room to paste them properly other than mounting vertically with mounting plates.
Share this post
Link to post
yep,fixed 3000k h3 and those fogs have projector lence like glass cover, so no glare.(they are identical to komis fogs as Eg,Teg have some similar parts). Got them from Ebay. Total cost was around 10k including the tax.No halo rings. Just 2 hours of DIY as had to remove the front bumper,otherwise its just plug & play.
Edited by H.C
Share this post
Link to post
so you had to pay tax? how much? I've brought down some but yet haven't come across tax. I'm also planning to fix those. How much did they take to fix?
Share this post
Link to post
Fogs came in a bit larger box and had to pay around 3000rs for it. I installed them at home with some helping hand from my wife! :)
Share this post
Link to post
I think the issue is with the Holder of the light. In Nissan there are few cars (FB15, wingroad ect) comes with "H4B" bulb type. Different is H4B holder is smaller than the normal H4. When you fix the normal H$ to H4B the bulb does not fix properly to the holder hence the light will scattered. I removed my exixting H$ and fix it to Allion which has normal H4 Holder. and it works fine.
If you can see the bulb type of the regional bulb u had in you FB15 you will see the difference
Share this post
Link to post
Not that actually, it is due to mechanism which use to create light. Halogen use heated filament and in HID uses an arc. Filament make light source over shape but arc more cylindrical(from Internet) and even in bi xenon uses single arc where as H4 uses 2 filaments. These deference makes light more scattered and ineffective in conventional reflectors.
Share this post
Link to post
hi
im looking for a HID H4 6000k kit with warranty, or a CREE H4 LED kit with warranty, plz let me knw if anyone is there
thanks
Share this post
Link to post
hi
thanks
Sorry I can't help you out right away with a name or location you can go to; but some locations in the Colombo area where you can go enquire are listed throughout this thread.
Anyways, props to you 'kani' for :
1. Using the search function
2. Posting in a relevant thread
3. Doing all this on your first post.
Good on you, and welcome to Autolanka!
Btw: 'kani' where are you located? And when you say 'looking for a HID H4 6000k kit with warranty, or a CREE H4 LED kit with warranty' do you need it to be an installed unit sold with a warranty in Sri Lanka, or can you make do with a warranty on the product off the seller' ebay site / manufacturer's website? ( If its the latter you will have to check with the manufacturer or seller if the warranty is still valid if you have it installed yourself in Sri Lanka.)
Edited by Kavvz
Share this post
Link to post
Hello,
I want to convert my light from halogens to HID. I've already bought an HID kit (35w, 4300K). I'll be getting HID projectors next week.
So basically is there any place that could do the retrofit for me? I don't have the tools to go about cutting into my headlight assembly and would rather let someone who actually knows what they are doing, do the job.
Going through the thread, seems like bara stereos can perform the job? Any other recommendations(I'm in Panadura so ideally Colombo would be the furthest I'd want to travel to)?
Thanks in advance!
Share this post
Link to post
