Project Moggie - Body & Electrical work
kusumsiri
Bodywork started after disassembling almost all parts. Remain only the outer shell of the car with wiring harness which can not pullout easily. Gauge 14 & 18 zinc coated metal sheets used for most places.
1.thumb.jpg.40b2699650b77bbcb307c01c43095c15.jpg2.thumb.jpg.13911513b63900f369e0dd1829dbcfd7.jpg
Firstly cut the right side of the chassis and welded new bar.
3.thumb.jpg.d40946ca58ed476765dc2d51e944ee8b.jpg4.thumb.jpg.1ef6cdb65511029e296d6dcad44bd8e2.jpg5.thumb.jpg.21268028b2994faeca970e6213a96aa2.jpg6.thumb.jpg.3d3750fdf6fd4a6a82933757837c27a9.jpg
Then the left side and floor board plates one by one. All door bottoms, front and back wings repaired. Mean time door hinge pins refilled at a lathe workshop.  Finally attached all doors and wings again to check the aligning.
Carbide 9kg and a oxygen cylinder consumed for this works.
27 Comments
Recommended Comments
Wow! That's a lot of work. Do you do your own tinkering? So once you cut out the chassis bar how do you prevent the roof from warping? The B pillar is not supported at the bottom, so doesn't the weight of the roof warp the structure?
Edited by varotone
I dont have tinkering skills to do the job. So got a professional tinkers service. He visited my home and did the job. Its took round 20 days. Seems he did the job well. Also according to my requirements. Welded iron bars across the edges before cut the chassis bar to prevent roof warping. Also the Morris Minor workshop manual refereed to find extract dimensions in this case.
Making good progress @kusumsiri! Keep it up!
One thing I can advise you on is to keep the wiring well away from the welding torch. While your tinkerer is cutting out external panels, there might be wires that go through small cavities that'll get torched in the process if not moved away or properly shielded.
Thks @Davy for the advice. You are correct. They are not caring about other things when working. If happened something will say "ටේප් කෑල්ලක් ගැහුවම හරි". I know those type of answers. So tried to be with him possible every seconds and told the things in friendly manner some times in jokes too. image.thumb.png.c85d4af95f089a19071530bae5a20bba.png
But unfortunately he damaged the control box cover. See the small hole. Might be he try to open it in wrong manner.
May I suggest removing all the wires while tinkering is going on. If wires can't pass through the holes in the firewall because the connectors are larger than the holes, remove the connectors. Note how wires are connected and remove all of them. Once it is outside, you can thoroughly inspect the wires for damages and fix it. It's easier to fix the wiring when it's taken out.
Regarding the damaged voltage regulator, how about upgrading to an electronic one? They stabilizer voltage better than the electromagnetic ones and don't need adjusting regularly. Just my two cents.
Most wires released from the clips, rolled and kept under the dashboard. But your suggestion seems better. Unfortunately tinkering work finished before your suggestion  :sad-smiley-050:. Also the previous owner said head lamp fuse burning time to time. So willing to check complete wire harness by removing all insulation tapes and check each wire for damage in the rewiring process.
Voltage regulator A alternator (3 wire) fixed already and the dynamo removed. The alternator should have a built in regulator which I dont need to worry about charging. But willing to keep the regulator as it is to have vintage look.
Some history : My father had a Austin lorry (a one like below) which had a dynamo. So I know the headache of charging. That is the lorry my father taught me driving. No serve brake, no power steering and the starter motor not functioning well because of that poor dynamo. Still remember that nice time period.?
It doesn't have a headlight relay right? And the rated power for headlights is 35/50W? Maybe the sealed beams are of a higher power. Might be the reason for blown fuse. I suggest you add a relay. Even the 35/50 would be brighter with the relay due to the decreased voltage drop. You can even upgrade to brighter lights later.
When you repair the wire harness route the wires through flexi tubing. Electrical wiring shops have something called flexi / flexi tubing. A corrugated flexible PVC tube. Get some black color heavy-duty ones and run the wires through it. Added protection from rodents and elements. Looks neat too. Especially useful for exposed wires in the engine bay. I just finished repairing all the wires in my project car. Assembled everything as it would be on the car with all the switches, lights and motors, and made sure all worked. Used the flexi also. Unfortunately I don't have photos of the whole setup on my phone.
Alternator is a worthy upgrade. Clean the gunk off the voltage regulator and attach some wires to keep the looks!
Cheers
Varotone
Yes. It dont have any relay. Your relay suggestion is good and seems practical. Deeply thinking about it.
About flexi tubing : The hardware guys call them as flexible hose and I already planned to use those. I will update here once done.
Regulator : Yep, thinking to attach some dummy wires to it. Now it have only 1 and seems isolated.
Update : Because we already discussed about electrical works in this thread added the relevant images here. To suit it changed the thread name from "Project Moggie - Bodywork" to "Project Moggie - Body & Electrical work". First two images shows the control box and fuse box in the way they were.
IMG_20180301_141455.thumb.jpg.a10fdd19bf82cf7ff49f0ad7b67fd4cf.jpgIMG_20190512_124427.thumb.jpg.88f7ee53868b92077661f8915337221c.jpg
This is how the viper motor and flasher were there.
IMG_20180301_141459.thumb.jpg.5ea554c49a05d38d46099912bb952f3d.jpgIMG_20190512_125614.thumb.jpg.f84943f13778061ba571b7d2af59cd7f.jpg
IMG_20190526_123838.thumb.jpg.1d5dd37cc41a9e73be4d615d1e18e82a.jpgIMG_20190526_123849.thumb.jpg.463a05e8337d1096e173b1853d278254.jpg
Below images are the present status of wiring. The hole on the control box cover was repaired and added some dummy wires to it for better look. Thank you @varotone for suggestion about flexi tubing.
IMG_20190601_080028.thumb.jpg.2df0a99b6fa62b1a7f25f34a3a5a8857.jpgIMG_20190601_080101.thumb.jpg.c1e657f8144712772fd54227ea8bdf4f.jpg
Original status and present status
IMG_20180301_141510.thumb.jpg.4f4c14f6c3449bede8bad610c8688d72.jpgIMG_20190601_080205.thumb.jpg.2e92d61b6b830666546fc879548f965a.jpg
1 hour ago, Twin Turbo said:
How bouts an alternator conversion?
One previous owner converted the wiring to negative earth and an alternator also fixed. It is a 3 wire alternator having inbuilt regulator. But the control box fixed as a dummy.
Update : (I am sorry it's around a year from last update) Realized that wiper motor cannot govern the load successfully. So decided to rewind it myself. Here are some images of the process.
IMG_20200924_072831.thumb.jpg.ad03dd763cdc4cf2b6ba6775371a7c8a.jpgIMG_20200924_073105.thumb.jpg.3216a41a5feb7ae0c6001215f7ba6e27.jpg
IMG_20200925_104256.thumb.jpg.e6437f77ad06b4655d2a64272b738e1e.jpgIMG_20200926_091432.thumb.jpg.e99a06b34a2b4d2811da6297efad463d.jpg
IMG_20200926_100540.thumb.jpg.499473cb6f078e65d41d1074e5d3b88e.jpgIMG_20200926_105234.thumb.jpg.58f2329c276b1fabf2b79f0029b73e82.jpgIMG_20200926_142444.thumb.jpg.90d718e2ce78d50a6e0cbbaf32f70054.jpg
  • Like 4
Mr,
Kusumsiri looks like you have completed the winding of the Armature correctly, like a professional Armature winder of Armatures, how is the speed when the wiper blades are on the glass. Always try with water do not operate dry, that can scrape the glass if any invisible dust is on the glass surface.
I can notice the Armature drive end of the Armature is little wasted. Check the bush on the wiper housing. Bush is not a brass bush it is a oil impregnated self oiling bush.
Finished product is very good.
Sylvester Wijesinghe
Sylvi.
Can you explain the three wire Alternator how the wire ends are connected.
IT IS CORRECT CHANGING THE WIRES TO NEGATIVE EARTH.
If possible try to change to a original Lucas Dynamo, because the Morris cars had originally dynamos. Pre era Alternator days the car was manufactured. You will be able to get a complete Dynamo for about Rupees 1000/= to 1500/=.
Sylvi.
Mr, Kusumsiri.
I read comments a bout Dynamo not giving enough Amperes to keep the Battery in full charge when the Engine is cold start. That has many reasons if I consider on Electrical system of the dynamo era before year 1970. can explain in detail, I do not want to write of those problems.
I  WILL EXPLAIN SHORT, THE BATTERY WILL HAVE TO BE AT LEASET 80% GOOD DYNAMO SHOULD GENERATE ENOUGH AMPEERS TO COMPANSATE BATTERY LOSS DUE TO SELF START MOTOR OPERATION DRAIN IN FEW MINUITS AFTER THE COLD START. WHEN THE ENGINE IN OPERATION. BATTERY EARTH TO ENGINE WILL HAVE TO BE CONNECTED CORRECTLY.
Above are the few problems which I have noticed in pre Alternator era of Dynamo days.
My observations about Alternators, they are efficient than Dynamos, they fill up the battery in double quick time due to high amperage they generate on low RPM.
Sylvi.
Member,
Do not blame Dynamos, they did very good efficient service before Alternator's was interduce in year 1960. From the time first Vehicles were manufactured in early 1900. All Military armored vehicles during 1st WW and 2WW had large Dynamos instead of Alternators. I have had the experience of repairing them in very early days of my life.
This problem is not on the dynamos the vehicle engines were not up to the slandered, Batteries were used more than their life time, due to wiring faults mostly bad earthing which I have come across in 70% of vehicles more than 10 years old, specially after tinkering work completed earth  wires not connected correctly.
Sylvi.
12 hours ago, Sylvi said:
Mr,
Sylvi.
Hello Mr. Sylvi,
It's nice to have comments from a member like you because you have enormous experience about these car mechanics and electric system. Secondly thank you for valuating my armature winding task.
  • Armature drive end : Yes you are correct again. The commutator is bit wear out. Unfortunately I could not find a matching commutator from local market. So decided to use the same. Hope it will serve me considerable time period.
  • Three wire alternator : This is what I used to do the alternator wiring and its charging the battery typically.
I do not blame Dynamo. I can imagine the dynamo era and how served dynamos to the vehicle owners.
22 minutes ago, Sylvi said:
Mr. Kusumsiri,
How far you have advanced on your project?
Sylvi.
Hello Mr. @Sylvi
It is almost finished. But I could not take her out because of this covid-19 pandemic. I will update with some photos ASAP.
Mr. Kusumsiri,
I do not loginto A/L much, that is the reason for delay in reply if any questions better you send me a Email <[email protected]> with a SMS to my phone 0112573690 so that I will attend promptly.
Where do you live so that I can come and have a look at your wiring the dynamo how you had connected the regulator. What is the (SWG) gauge of wire you used for the Aramature winding?.
Sylvi.
3 hours ago, Sylvi said:
Mr. Kusumsiri,
Sylvi.
Mr Sylvi,
Thank you again for your kindness and contact information. Unfortunately I live a little far from Colombo. That is Embilipitiya. The Alternator having inbuilt regulator. So no need to use original regulator. But I kept the original regulator and did some dummy wiring to get thee classic look. Used 28/0.30mm Kelani cable for Lucas DR2 wiper motor armature winding.
kusumsiri,
Embilipitiya is not new to me I did the power wiring of Sevanagala allmost 35 years back. our main town daily I visit in the evening for our (jaya 37%  Panaya) requirement. In the morning for daily Fish an beef or any other jungle four legs.
I have my assistant  very close at Angunakolapaallasa. Can give contact if you want any help before Monday he will come to your door step.
Sylvi.
12 minutes ago, Sylvi said:
kusumsiri,
Sylvi.
Mr. @Sylvi
I'm sorry for my misunderstanding. You are always welcome to my place in your next Sevanagala visit. If so we can have a ride with Moggy.
3 hours ago, kusumsiri said:
Mr. @Sylvi
Mr. Kusumsiri,
You home town is Embilipitiya? that area is very beautiful town, like to come and recollect my memories what we spend with 35 Electricians and few chaps for our help to live there, will try to make it one day soon.
First I will go to Angunukolapallasa, then come there. Will inform early.
Sylvi.
21 hours ago, Sylvi said:
Mr. Kusumsiri,
Sylvi.
This is not my home town. But I moved here from Passara 8 years ago. You are always welcome.
Add a comment...
