  • entries
    55
  • comments
    41
  • views
    26,888
Project R - Redux - from 2014 to 2018: INTERIOR
Komisiripala
the interior underwent a few subtle changes during this period.
the black paint started to rub off of the original tan interior after a few years and this started bugging me quite a bit. added to this was the fact that the ITR coupe and sedan had doors which were lighter than the LS/GS/GSR trim doors. even the glasses were thinner to save weight. after much hunting, i managed to source an original black dashboard from a dismantled car in the UK, and had it shipped over.
the painted dash had a grainy lacklustre finish to it, which was rather irksome. i knew it was painted, and in my mind it looked painted.
the OEM black tho, looked just perfect when polished. also seen in the below photo is the interior trim of the ITR sedan door. i sourced the doors from a dismantled car in malaysia.
17632057_10154509558113333_1268116496245343898_o.thumb.jpg.a1cf2c0e3b091ae186a8befa05142965.jpg
the center of attraction of course are the 3 52mm Defi Advance gauges mounted on the winsdscreen. these have quite a story behind them. original Defi gauges are rare and expensive. and the local market is flooded with so many knockoffs that i really didn't want a local supplier to get me a fake set. after much hunting i found these online on Yahoo Japan. they were off of an Evo7. the bidding ended at nearly 50,000 Yen, and the auction was set to end on a day i would be at the Motorshow representing LIMITLESS. not wanting to lose such a pristine set, i asked for help from our fellow autolankan, @Muditha420. i handed over my login details, and he religiously watched the auction and bid on my behalf, winning this in the last split second, outbidding over a dozen other bidders. i don't think even i would have had the fortitude to see this through! i am eternally grateful!
17505161_10154509558933333_1176075874373465918_o.thumb.jpg.60e151cbddc0a802b0d4f582ea4ec623.jpg
14086195_1804039213145643_8299226706662556185_o.jpg.07c86f596dfa41de9612dd15c7be382d.jpg
i've added these for good reason. firstly, the gauge on the extreme right shows the water temperature. optimal temp is 90C. the corresponds with the water temp gauge in the car. the middle gauge indicates oil temperature. this is a more important reading, as the oil takes longer to heat up, and the engine should not be overrevved until the oil is at optimum temp, in order to prevent bearing failure. as the water temp rises much faster, the car's temp gauge is NOT a reliable indicator of when you can trample it.
the gauge on the extreme left is the oil pressure gauge. this would indicate a drop in oil pressure in the case of an oil leak.
of course apart from all this the coolest thing about them is the Blood Horsepower level boost you get when you crank the ignition and see them do their diagnostic sweep. #andenawa!
apart from these i've also made use of the two dummy switch deletes on either side of the indicator stalks to install 45mm Proposrt gauges, indicating fuel pressure and stoichiometry. for some reason the stoich gauge never worked from day one. i suspect its not getting the right input parameters. i will fix it. eventually. its not really a concern for now.
17620577_10154509558048333_9039864057464927110_o.thumb.jpg.986717c6c99aa9dc3aa9d492023c8a2c.jpg
both gauges are seen through the steering in this shot. left is fuel pressure and right is stoichiometry
i've gotten rid of the unsightly rubber bucket carpets and opted for the black nylon wool 3M custom cut mats. they look a whole lot classier. eventually hoping to source the OEM ITR sedan carpet set from japan.
last but not least, the piece-de-resistance: with great difficulty and much research, i found the OEM head unit that came as spec for the integra. sadly the Type R version is over 400$, and it only has faux carbon fiber printed on the surface, and "type r" written on it. this is off a non R, but its the same thing. only goes up to 90FM, but since im a fan of Lite and EFM, it matters not. quite a cool little device tho. i love the motorised sliding face!
apart from this i've also gone for a full tint on all glass surfaces with 3M's 90% clear UV tint. it cost a packet, but the tint itself is not visible and it works well to cut the radiant and UV heat from the sun. as this car has a large glass bubble due to the extreme rake of the rear windshield, the greenhouse effect is quite pronounced when parked in the sun for even a short while. the 3M tint really does deliver what it promises. i can leave this parked in the hot sun the whole day and the cabin is bearable when entered. also the AC cuts off so much faster and the cabin retains the cold for a lot longer. the gas mileage has improved by almost 2kmpl in traffic. i kid you not. comes highly recommended.
another interesting piece of kit i managed to source were the aluminium pedal set. this came as an option on the 2001 Type Rx, which was the last hurrah of the DC2, before it was discontinued. the Type Rx had dual airbags, a factory AC (AC was deleted in the first gen ITR's and later given as a factory option) dual power mirrors, plusher carpets, and the aluminium pedals. it was more a cosmetic upgrade. it also was the rarest of the integras! got hold of a pedal, and two pedal covers yahoo japan, and on they went. this was after seeing the Legacy B4 aluminium pedals on @Muditha420's car. mine were sadly nearly thrice as expensive as his :-/
2 Comments
Recommended Comments
Every time I see this interior, it makes my heart leap. There should be a picture of this dashboard in the Sinhala dictionary under the phrase "Budu Ammo!".
  • Haha 1
Add a comment...
